CCME in SOHO :- Diverting Fax calls to fxs port
I have a situation where a custom is will have CCME and has a fax machine attached to an FXS port.
All PSTN calls come through a single FXO trunk.
There is no DID for FAX calls.
If I want to divert incoming fax calls to go to a dial-peer on which the fax machine is attached, do I need to setup the TCL script for Fax detection ?
1 REPLY
Hall of Fame Super Gold
Re: CCME in SOHO :- Diverting Fax calls to fxs port
Hi, I've tried a tcl script with the commands for fax detections, and could not have it working.
So I think you need to direct the call via an extension anyway.
116
