Community Member
CCME Inserting the 9
I have a few questions, but I'll put them into separate posts.
With CCME, is it possible to insert the '9' into the number when you press redial, or when one dials from the directory?
Ohamien
1 ACCEPTED SOLUTION
Re: CCME Inserting the 9
You can automatically prefix a 9 or 91 using a translation profile and then apply that to the incoming dial peer.
Community Member
Makes sense.
Thanks!
Ohamien
136
