CCME interoperability with 3Com V3000
Hello to all I'm posting this thread to get some help om implementing Cisco CME through H323 with another vendor, in this case 3Com V3000. Here's the setup, I have 2 sites one with CME already working and another site (Site 2) with a 3Com NBX V3000 also using 3com's switches. 3Com states that it's Connextions software (H323 gateway) is capable of using g723.1 codec, but is not, since when I connect between them using transparent codec setup on the CME it works (cheapy but works) but when I configure g723r63 codec it connects to the gateway but no audio is heard.
Just to see if any other people have connected two systems like these ones. Any input will be appretiated.
Mampostial
1 REPLY
Re: CCME interoperability with 3Com V3000
Hi, just want to know do you need Connextions to implement CME or CCM with NBX? or can be done with out it?
181
