CCME & LCS2005
Hi to all,
I have a LCS 2005 SP1, at this time we use it only for IM services. But now
we want to integrate it our with IPTelefony provided by Cisco Callmanager
Express, we want permite to communitate beetwen Live Communicator and IP
Phone, and use CCME as PSTN gateway for Live Communicator. CCME can manage
SIP communications (for example IVR, fax, etc...) and now IP phone use SCCP
procotol.
Some body can help me? bacuase I don't find any tecnical document about
that!
Thank you
Augusto.
Hall of Fame Super Gold
Re: CCME & LCS2005
Augusto,
if you want to do SIP trunking between CME (and any type of phone it controls) and another SIP device, live communicator or whatever it is, sure it should work. Just use regular dial-peer configuration on CME.
Re: CCME & LCS2005
I already configure a dial-peer, like this:
dial-peer voice 42 voip
description Live Communications 2005
destination-pattern 5...
session target ipv4:192.168.254.226:5060
dtmf-relay h245-alphanumeric
codec g711ulaw
Right?
Augusto.
Re: CCME & LCS2005
That would be an H.323 connection. For SIP, add "session protocol sipv2". You don't need to specify the port 5060 unless you want to change it.
Re: CCME & LCS2005
Right! It's my stupid error, I have to use sipv2!!!
Thank.
Augusto.
95
