CCME LOGIN softkey
shaik.dawood
CCME Version 7.0.1,IOS Version 12.4(22)T
is misbehaving when pressing login softkey to add password for endusers international dialing. Customer is facing serious issue when he reboot with the IOS, IP Phones are getting different Extensions meanwhile, any solution, after creating after-hour pattern and assign the Pin no for the DN. we press Login, its dialing unknown number everytime, is there any bug
paolo bevilacqua
You could try 12.4(20)T2 and check if any problem.
Never deploy new IOS without doing a testbed first.
Thanks for the reply
IOS was 12.4 (20)T before,we face the same issue. I had a doubt with IOS and I upgraded, now the situation became worse, phones are getting different numbers randomly and Login issues are not fixed still, any suggestion
I said 12.4(20)T2, that is different from 12.4(20)T.
You can also go back further, eg latest XW, latest XJ, etc.
