09-03-2009 01:29 AM - edited 03-15-2019 07:37 PM
There is a button configuration in CUCM that corrispond to the "m" (monitor) or "o" (overlay) flags on line button under CCME?
examples:
ephone 1
button 1:1 2:5 3o20,21 4m2
Many thanks.
09-09-2009 10:34 AM
To associate ephone-dns with individual buttons on a Cisco Unified IP phone and to specify line type or ring behavior, use the button command in ephone configuration mode.
button button-number {separator} dn-tag [,dn-tag...] [button-number{x}overlay-button-number] [button-number...]
m-Monitor mode for a shared line. Visible line status indicates whether the line is in-use or not. Monitored lines cannot be used on this phone for incoming or outgoing calls.
o-Overlay line. Multiple ephone-dns share a single button, up to a maximum of 25 on a button. See also the c keyword.
09-11-2009 12:01 PM
Hi, in my knowledge there are not these features implemented in CUCM.
For the monitor feature you can use a BLF (Busy Lamp Field) button or a BLS w/SD (with Speed Dial) to "emulate" the behaviuor.
For overlay button you can configured shared lines or hunt lists, but it is not the same since you can assign only a line to a button in CUCM.
