CCME on 2811 device backup configuration
Hi All,
I'm configuring a 2811 CCME with 2 WIC ISDN double ports and I'm configuring a GSM Quescom gateway to send all the calls direct to mobile phones from IP phone to Quescom through 2811 router. Now if I call a phone in my city, country, state and etc. I use only ISDN ports and if I call a mobile phone I use only GSM gateway. Now I ask you if GSM gateway has broken or GSM cell is down is it possible to call through ISDN line automatically? Which commands have to use to configure 2811 to call another device (WIC Interface) when the default device (Quescom) is not avaible? Thank You for help
Kind Regards
Antonino
Hall of Fame Super Gold
Re: CCME on 2811 device backup configuration
Antonino, you have to be confident about your quescom device. either it works and is reliable, or it doesn't. rememeber to configure "max-conns 1" unde the dial -peer in case it ihas only 1 sime, and use a trunk-group configuration with an higher preference to send calls via PSTN as secondary preference.
Hi Paolo,
thank you for answer, I believe Quescom is very good product!!!, but I try to follow your advises but when I apply command syntax I have an error:
-In the dial-peer voip:
Router(config-dial-peer)#trunkgroup 10
ERROR: Incorrect use of config_dialpeer_trkgrp
-In the dial-peer pots:
Router(config-dial-peer)#trunkgroup 10 5
ERROR: voice port exists
On the bottom there is part of router configuration
dial-peer voice 100 voip
description To Quescom
destination-pattern 3...T
session target ipv4:192.168.168.5
dtmf-relay h245-alphanumeric
codec g711ulaw
vad
dial-peer voice 101 pots
destination-pattern 0...T
progress_ind setup enable 3
progress_ind progress enable 8
port 0/0/0
forward-digits all
dial-peer voice 102 pots
port 0/0/1
forward-digits all
Have you idea why the command has refused.
Thank You for best support
Kind Regards
Antonino
This is the configuration for a device with only 1 sim, 1st call is via 'topex' TG, further calls use another TG. remember to configure 'no port' beforeyou configure trunkgroup.
dial-peer voice 3933 pots
trunkgroup topex
trunkgroup fastweb 10
max-conn 1
destination-pattern ^33[^2]......T
no digit-strip
trunk group topex
max-calls any 1
interface BRI0/2/1
trunk-group topex
Following the other DPs for cellphones in Italy. Good luck!
dial-peer voice 3932 pots
description Wind
destination-pattern ^32[03789].......
no digit-strip
dial-peer voice 3938 pots
description Wind
destination-pattern ^38[0389].......
no sip-register
dial-peer voice 3936 pots
description TIM
destination-pattern ^36[0368]......T
dial-peer voice 3934 pots
description Vodafone
destination-pattern ^34[036-9].......
dial-peer voice 3939 pots
description H3G
destination-pattern ^39[0-3].......
551
