CCME password Change
Hi, i have a ccme 8.0 with unity express 8.0 running; if i change the username/password in the ccme, is there any risk of loosing ccme/unity integration?. My question is because when you run the unity gui initializtion wizard, the system prompts for callmanager administrator user and password.
1 ACCEPTED SOLUTION
Re: CCME password Change
Yes, you'd get error connection lost/refused while trying to access CUE GUI...
The userID and password of CME that you enter in the CUE init wizard
needs to match the web admin userid and password configured under
telephony-services (CME)
If you do change that on CME, you need to make sure to update it on CUE
by going to
  Configure -> System Parameters -> Administrator's Login Account page
by going to
Thank you.
232
