CCME phones display wrong time...
I'm working on a ccme system that's having time issues. The router and Unity express display the correct time but the phones are showing a time 4 hours ahead. NTP is configured and working. Anyone seem this before?
The system is CCME 3.3 running on IOS 12.4.16.
Justin
Re: CCME phones display wrong time...
Can you post your configuration?
Your "time-zone" under telephony-services may be set wrong if your "sh clock" is set correctly. Also what phones are you using?
Justin,
Have you set a value for time-zone under the Telephony Services in the IOS? After you change that value, you need to re-generate your cnf files with a "create cnf" command.
--Luke
134
