Community Member
CCME select dial-peer
Hi, my customer has connected two gateways gsm to the ccme. Could be possible select one or another to out mobile calls in function on the calls hour ?
Many thanks,
DS
1 REPLY
Hall of Fame Super Gold
Re: CCME select dial-peer
No, not directly. You will need an external script that change configuration to do this.
141
