Community Member
CCME SIP provider Problem
Hi all,
I have a strange problem using a ccme versione 4.1(0) on a router 2800 IOS: c2800nm-advipservicesk9-mz.124-15.T5
The CCME is correctly registered on a sip provider.
Some times when I have an incoming call i have the Ring "Free" but after 3 ring the call goes down "in busy state" but the phones do no ring.
IF i have a look at the "sip-ua calls" i have a situation as:
SIP UAC CALL INFO
Number of SIP User Agent Client(UAC) calls: 0
SIP UAS CALL INFO
Call 1
SIP Call ID : 04ca778d7b3c764b6791b9857f91dbe0@194.244.11.18
State of the call : SIP_STATE_OPTIONS_WAIT (27)
Substate of the call : SUBSTATE_NONE (0)
Calling Number : kebuIPPBX
Called Number : 41484
Bit Flags : 0x40000C 0x104 0x0
CC Call ID : 199051
Source IP Address (Sig ): 81.174.35.83
Destn SIP Req Addr:Port : 0.0.0.0:0
Destn SIP Resp Addr:Port: 194.244.11.18:5060
Destination Name : 194.244.11.18
Number of Media Streams : 1
Number of Active Streams: 0
RTP Fork Object : 0x0
Media Mode : flow-through
Media Stream 1
State of the stream : STREAM_IDLE
Stream Call ID : -1
Stream Type : voice+dtmf (1)
Negotiated Codec : No Codec (0 bytes)
Codec Payload Type : 255 (None)
Negotiated Dtmf-relay : inband-voice
Dtmf-relay Payload Type : 0
Media Source IP Addr:Port: 81.174.35.83:0
Media Dest IP Addr:Port : 0.0.0.0:0
Orig Media Dest IP Addr:Port : 0.0.0.0:0
Options-Ping ENABLED:NO ACTIVE:NO
Number of SIP User Agent Server(UAS) calls: 1
I don't know why. My opinion is a software version problem.
Re: CCME SIP provider Problem
You'd want to look at 'debug ccsip messages' for the failed case. It's possible it's not even getting to your router. If it is, it could be a call routing problem.
hth,
nick
Community Member
Thanks Grate debug. I make 3 calls but no error tomorrow I will try again to log a wrong call.
What do you mean call routing problem?
FX
Community Member
Hi, I add a new information:
Lokking at the logs with sip provider, the ccme refuses the call and the error in the sip provider is "busy congestion".
Any ideas.
You would need to check your dial peer configuration against the incoming sip messaging. This means debug voip dial peer, debug ccsip messages
You would want to use this command:
show dial-peer voip summary
hth,
nick
281
