CCME VIC2-2BRI-NT/TE
Hi, we have a VIC2-2BRI-NT/TE and the layer 1 is deactivated. The ISDN line is a point-to-multipoint , and the carrier has test the line and all is correct (include the cable that arrive to the card). The IOS is 12.4.(4)XC4 (before upgrade we use IOS 12.4.(4)XC ) , and we use two different cards (VIC2-2BRI-NT/TE), that in another installatio work propertly..The BRI config is :
interface BRI2/0
no ip address
isdn switch-type basic-net3
isdn incoming-voice voice
isdn static tei 0
FYI , when a outbound call arrive the layer 1 is actived , and then during 4 minutes aprox. we can raise a calls. Any idea ? Is very strange problemm..
Many thanks
Re: CCME VIC2-2BRI-NT/TE
Ive found that the BRI works best on PTP had quite a lot of issues with PTMP links.
what is isdn q921 and q931 debugs tell u ?? can you post a debug and what switch type are you connecing to ??
interface BRI0/0/1
no ip address
isdn not-end-to-end 64
isdn point-to-point-setup
isdn static-tei 0
Hall of Fame Super Gold
Hi Davey,
previously I've suggested the same than you, and asked for the same traces.
Got no reply.
158
