CCME with vg204 for fax call
Helo guys i am having ccem 2912 and vg204 that is registered with ccme...
i have connetced fax with vg304 gateway and having PRI line on CCME router.
now i want to send and recieve fax calls over this setup..
Please tell me which dila-peers are needed for this setup done perfectly.
thanks for your all suggestions...
thanks
i have added the latest configuration of cme and vg204 gateway.
my fax extenison num,ber is 040....(DID is 4462040)..
please tell how it work?
Warm Regard's =========== Amit
1 REPLY
Hall of Fame Super Gold
You don't need any special dial peer.
Just configure fax relay as explained in cisco documentation. For that is better to use the port in H.323 or SIP mode, not SCCP.
285
