Community Member
CCME
i have a uc500. I want the dial tone (when the users off-hook the phone) be different of the tone received after dial the 9 digit (secondary-dialtone). How can I do that.
Thanks.
1 ACCEPTED SOLUTION
Re: CCME
Hi rafaeljimenez,
This can also be done on the CME admin web interface. Click Configure, then System parameters. You will then see a menu on the left hand side, click "Secondary Dialtone"
HTH, Please rate if so.
Justin Brenton
Hall of Fame Super Red
Re: CCME
Hi Rafael,
Hope all is well :)
secondary-dialtone
To activate a secondary dial tone when a Cisco IP phone user dials a defined public switched telephone network (PSTN) access prefix, use the secondary-dialtone command in telephony-service configuration mode. To disable the secondary dial tone, use the no form of this command.
secondary-dialtone digit-string
Examples
The following example enables a secondary dial tone when a Cisco IP phone users press the digit 9 to get an outside line:
Router(config)# telephony-service
Router(config-telephony)# secondary-dialtone 9
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html#wp1021511
Hope this helps!
Rob
Hall of Fame Super Gold
Re: CCME
This depends on the network-locale set under telephony-service.
If the configured country doesn't have defined a different tone, you can try changing country or looking at g3-tones.xml customization file. But not all phone models actually use g3-tones.xml.
Re: CCME
Hi rafaeljimenez,
Justin Brenton
143
