CCMUser Custom
Hi people.
It's possible customize the ccmuser? My customer wants change the Logo Cisco and put his logo.
Peterson
1 ACCEPTED SOLUTION
Red
Re: CCMUser Custom
I would just tell my customer it's impossible. If you really want to do that, there can only be two ways:
1) Hack the system and get to root shell. Once you get to root shell, it should be easy to find out the logo file and replace it.
2) Build a customized web site and use AXL to fulfill the function of CCMUser web.
Neither one worth the efforts if changing the logo is all you want.
Michael
Red
Re: CCMUser Custom
Everything's possible, depending on how far you want to go :) Check this doc: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/devguide/7_1_2/AXL_DevGuide.html
Michael
http://htluo.blogspot.com
Re: CCMUser Custom
Hi Michael
I don't found the example to change apache code.
On CUCM 5 and 6 do you already changed the logo cisco on ccmuser page?
Red
Re: CCMUser Custom
Michael
Re: CCMUser Custom
Thanks Michael
I'm reading your blog
469
