ccmuser login failed...
hi there,
i am tried to log on to a phone using the ccmuser login page but i am not getting any success .. error is resourse not available or some times login failed error only. please help
web address using is http://X.X.X.X/ccmuser
authentication is from AD/LDAP, CUCM 6.1
Everyone's tags (1)
1 REPLY
Re: ccmuser login failed...
Was this working before??
If no, I'd recommend you to review the authentication configuration because most likely it's wrong.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
786
