ccmuser page session timeout
pwenger
Level 3
Level 3
Is there a way to increase the timeout of the ccmuser page in CUCM 7.x?
Cheers
Peter
9 Replies 9
sbilgi
Level 5
Level 5
Try this to solve the timeout problem
Click on start ---- programs ---- administrative tools ---- internet services manager
------ expand on cm icon ----- Right click on Default Web site option -------- click on
properties ----- select web site option from the properties above ------ In the connection
timeout box change the value from default 900 seconds (15 minutes ) to the number of
seconds of your choice. Now restart IIS service.
It's CUCM 7.x, so there is no Microsoft Windows anymore!
Peter
any luck with this? I have the same issue on ccm6
There is no way to change this
CSCsj45520
CM 6.0/7.0 Customer should be able to configure/disable CCMAdmin timeout
This has been asked plenty of times before, PLEASE search NetPro for answers.
java
if this helps, please rate
java
He was talking about CCM User page.
Can you confirm it is the same issue for this part?
thanks,
Thomas
Yes, the info is the same for both.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
It's been so long I can't remember. Is it possible to set for admin or user at all?
You cannnot set a login timeout for either of them
java
java
Ok thanks,
The using of webdialer was really boring, and will remain the same
Bye,
Thomas
