ccmuser phone guides
i have a cucm ver 8.6.20000 .
when i goes to ccmuser page  in the user option >   device >   i see my phone (7961) and ander that we have "user guide" : download user guide.
when i click on it  i get the pdf for this model this is fine . but when it is an 6921 model i get an error " http status 404 " the pdf is not available  .
i copy the url from other cucm and just replace the ip address on my array and it was fine  . it seem that the url isn't point to my PDF  . Cucm8.6.bmp
how can someone help to solved that please ?
Hall of Fame Super Red
Hi Sharon,
It sounds like this bug;
CSCue80984 Bug DetailsBug #36 of 46 | < Previous | Next >
PhoneOnlineGuide/6921_41_61/6921enu86.pdf does not exist.
Symptom:
Problem Details:
env)
-CUCM8.6.2
-6945 IP Phone
-locale=english US
probem)
-login to ccmuser and click 'download user guide' on the device menu and I got the below message
HTTP Status 404 - /PhoneGuides/locales/en_us/PhoneOnlineGuide/6921_41_61/6921enu86.pdf
type: Status report
message: /PhoneGuides/locales/en_us/PhoneOnlineGuide/6921_41_61/6921enu86.pdf
description: The requested resource (/PhoneGuides/locales/en_us/PhoneOnlineGuide/6921_41_61/6921enu86.pdf) is not available.
Conditions:
Broken on 8.5 and 8.6
Workaround:
Provided the guide available in CCO
More info:
[root@CUCM862PUB ciscotac]# find / -name '*.pdf'
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7961/6141sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7961/6141sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7985/7985user.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7937/7937sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7962/6242sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7962/6242sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7960/6040sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7960/SCCPiph60pdf.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7960/6040sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7960/iph60pdf.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/3911/3911user.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/8961_9951_9971/8961sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7975/7975sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7975/7975sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7931/7931user.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7902G/7902Gqs.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7902G/02sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/3905/3905sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7905G/5GSCM.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7905G/0512sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7905G/0512sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/6901_11/6901-11enu86.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/6921_41_61/6921sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7911/11sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7911/0611sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7911/11sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7911/0611sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7970/7071sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7970/7970user.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7970/7071sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7921/7921user.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/3951/3951user.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7935/7935user.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7925/7925user.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7936/7936user.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7965/6545sip.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7965/6545sccp.pdf
/common/log/taos-log-a/cm/phoneguide_locales/en_us/PhoneOnlineGuide/7920/User7920.pdf.
Status Status
Open
Severity Severity
4 - minor
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified Communications Manager (CallManager)
Technology Technology
1st Found-In 1st Found-in
8.6(2.2000
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
Hello,  How does the work
Hello,  How does the work around works I did not get it.  Please, help.
Re:ccmuser phone guides
Oopss badle
thanks
Sent from Cisco Technical Support Android App
513
