ccmuser Web Directory
Working on a CM 7.1(3) with local user database and extension mobility.  User device profiles are associated with each user ID.  The corporate directory on the phones show the primary number of the UDP, but the directory on the ccmuser web page automatically shows all the phone numbers associated with a user's UDP.  Some of these numbers are private lines.  Is there any way to block certain UDP lines from showing up in the directory, or to turn off the directory from being an option on the ccmuser web page?
1 ACCEPTED SOLUTION
Silver
Re: ccmuser Web Directory
In Enterprise Parameters search for:
This parameter determines whether or not the option Directory appears on the Cisco IP Phone Options web (CCMUser). If this option is enabled, the user can search directory.
This is a required field.
Default:  True
: Change will take effect on next login to Cisco CallManager User Options window.
Silver
Default:  True
That'll work!  Thanks!
351
