12-13-2007 04:42 AM - edited 03-15-2019 07:46 AM
12-13-2007 05:29 AM
If you are running CM 4.1 and above, you would need to use the URL https://IP_Address_of_CM/ccmuser as CM 4.1 onwards does not support http.
Hope this helps
12-13-2007 06:04 AM
i am also type https. then also same problem is there any thing to enable in ccm. i am using ccm5.X????
