Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
CCNA Voice Lab - Suggestions?
Hi There,
<br /><br />I'm starting to prepare a lab for my CCNA Voice and eventually CCVP and was trying to come up with a simple but full lab topology for this. I have been using GNS3 but with the limitations of not having CUE is not fulfilling the requirements.
<br /><br />My first thought is to have 2x2800 series routers with CME and CUE connected through T1 cards with a pri crossover cable with some FXO/FXS and ATA's.
<br /><br />Do anyone have any suggestions on this lab?
<br /><br />Thanks,
<br /><br /><br />Justin
1 REPLY
Hall of Fame Super Gold
Re: CCNA Voice Lab - Suggestions?
Hi, that is OK, but 2800's and related HW are expensive for lab use. You can pretty much build the same scenarios with 1760 and 2610XM, on which you can fit an AIM or NM CUE.
300
