CDR and line group member DN
On a CallManager 7.0.2 I have to make statistics on line group members answering calls.
In service parameters I changed the option "Show Line Group Member DN in finalCalledPartyNumber CDR Fields" to enabled but in fact, in the CDR
appears the phone "external phone number mask" instead of the DN.
The doc I read : http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/5_1_3/car/caranrpt.html
This a big issue for my customer because lot of phone have the same external phone number mask.
Question; Is there a mistake in the doc or is my CallManager bugging ?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: CDR and line group member DN
Hi Guy,
It's buggy
CSCsm42428            Bug Details
External Phone Number Mask Applied to finalcalledparty  in Hunt-List CDR
Symptom:
The "finalcalledparty" field in the  calldetail record found on a Cisco Unified Communications Manager server  is populated with the value of an external phone number mask after a  call is placed to a hunt list.
Conditions:
This  will occur if the "Show Line Group Member DN in finalCalledPartyNumber"   is set to true and a calls is made to a hunt list.
Workaround:
Remove  the external mask from the DN in the hunt list
StatusStatus
Fixed
Severity Severity
6 - enhancement
Last Modified Last Modified
In Last 7 Days
Product Product
Cisco Unified Communications Manager (CallManager)
Technology Technology
1st Found-In 1st Found-in
4.3
7.0(1)
6.1(2.1000.13)
Fixed-In Fixed-in
8.5(0.94040.36)
7.1(4.98000.135)
7.1(4.18)
7.1(4.19)
7.1(4.21)
7.1(4.22)
7.1(4.23)
7.1(4.24)
6.1(5.11006.1)
7.1(5.10000.12)
8.0(2.11001.3)
8.0(1.11005.1)
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Hi Guy,
I believe that 99% of the build/upgrades will still use the
Restricted version. Have a look at this good thread;
http://www.gossamer-threads.com/lists/cisco/voip/129991?do=post_view_flat#129991
So, you could go to CUCM 7.1(5) without the .cop file
Cheers!
Rob
Hi Guy,
It's buggy
Symptom:
Conditions:
Workaround:
StatusStatus
Fixed
Severity Severity
6 - enhancement
In Last 7 Days
Product Product
4.3
7.0(1)
6.1(2.1000.13)
Fixed-In Fixed-in
8.5(0.94040.36)
7.1(4.98000.135)
7.1(4.18)
7.1(4.19)
7.1(4.21)
7.1(4.22)
7.1(4.23)
7.1(4.24)
6.1(5.11006.1)
7.1(5.10000.12)
8.0(2.11001.3)
8.0(1.11005.1)
Cheers!
Rob
Hi Rob,
Thanks so much for your answer.
In fact I need external mask on my DNs because of my outbound calls policies and all phones in a given line group have the same external mask so I have to upgrade. I tried to remove the mask and effectively I could see the change in the CDR.
Strangely when a user intercept a call in the line group the CDR is ok but not if he answers directly.
Kind regards
Guy
Hey Guy,
You are most welcome my friend! Yes, that is a pretty weak
work-around I must say. If you can hold off for a little bit before
upgrading to 7.1(5) I would do so Stay away from 8.0 for sure.
Cheers!
Rob
Hi Rob
I am confusing while downloading my upgrade files . It is talked about "restricted" and "unrestricted" 7.1.5 version.
The customer is a private end-customer in France which one is allowed ?
I do not want to upgrade under 7.1.5.
Hi Rob
Sorry please forget my question about restricted I have found information about that
I think I'll upgrade to 7.1(3b)su2.
Hi Rob,
The bug is not fixed in 7.1(3b) and there are no more 7.1.4 downloadable on CCO and 7.1.5 have this restriction policy and no path to 8.0.
What can I do ?
Hi Guy,
Cheers!
Rob
Thanks Rob,
Because I am not sure of the impact of such an "experimentation" on my customer life cycles I really wonder what do I do.
Hey Guy,
I'm totally with you here my friend
I would take my time here before I made any decisions on an
upgrade path. CUCM 7.1(5) is pretty new and although I haven't seen or heard
any truly distressing war stories about it, I'd want to do my normal
"due diligence".
It wouldn't seem like this type of issue should be "mission critical" and force
a quick move forward. Open a TAC case to see if they have an ES that addresses
this issue as a first step.Discuss with your management the pros/cons of such a
change if you must move to 7.1(5).
I know this doesn't answer your immediate concerns, but................
"patience is a virtue" especially with CUCM upgrades
Cheers!
Rob
917
