Community Member
CDR Backup
I am planning a upgrade from 4.x to 6.x call manager. CDR records older than 180 days will be deletedduring DMA import. I dont want to delete CDR records, instead I would like to backup CDR data. How can this be acheived.
-prakash
Bronze
Re: CDR Backup
You need to backup them manually,
The version of CAR that runs on Cisco Unified Communications Manager 6.1(2)
does not retain CDRs older than 180 days in the CAR database. If you
migrate records older than 180 days, the system deletes them immediately
after you upgrade. The Cisco Unified Communications Manager installation
program limits the time in which CAR records are migrated from the DMA
TAR file to the CAR database on the upgraded system. The installer
migrates approximately 100,000 to 150,000 of the oldest individual CAR
records within the time limit.
Any records that cannot be exported during the specified time will not
be migrated."
Community Member
Re: CDR Backup
How do I backup CDR manually
-Sridhar
307
