CDR Block Device/Line in Reporting
Hi Folks!
We are using CDR on CUCM 8.6 and I would like to know if it is possible to block or hide a Device or Line of being reported. Like the phone of CEO or some special managers not beeing reported. Maybe there is a flag I can setup in CUCM or CRD to do this?!
Hope for your help and comments!
Regards.
Everyone's tags (6)
2 ACCEPTED SOLUTIONS
Reports cannot be customized, you cannot add/remove fields.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Correct, if you want enhanced capabilites, you would need to use a 3rd party app
java
java
java
java
Hi Jaime,
thanks for your comment so far. Does this also mean, that it is not possible to just collect information of offnet calls and hide onnet calls being reported?
Thanks!
java
java
133
