cdr / cmr configuration
can any one please guide me how to configure cdr/cmr on cucm 6.1. and what all da
ta we can take out. can we do it automatic. i just want to take the information of outgoing calls from each extension. Called
number, time, connection time things like this . please help
Everyone's tags (2)
Re: cdr / cmr configuration
You need activate all CDR services. And set SFTP server in CDR Management. After it you can parse logs with field calling, called, time, duration.
Thanks for the quick answer ... but can you please elaborate it as i dont want to take chances with my production. we have got few clients running on this . please guide me ith the services and steps ..
Thanks a ton in advance
You're missing the most important step which is enabling CDR, just enabling the services doesn't enable CDR.
You need to enable this 2 paramenter in every server.
CDR Enabled Flag
Call Diagnostics Enabled
We already offer CAR so the biling server config is optional.
You can read the CAR documentation here.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
hi java thansk for the reply... i will surely check the answer one more thing i have posted two mote question since morning those are equally important as this one is can you please give some ideas.. i shall be very thankfull to you
hoping for the best and fast reply
Jatin
303
