CDR Destination Device not always being filled in.
We have two 2921 gateways. Each has multiple PRI circuits. For outbound calls going through just one of the PRIs, CUCM is not recording the destination device in the CDRs. Yet, for inbound calls on the same PRI, CUCM is recording the source device correctly.
Inbound & Outbound calls going through all the other PRIs, source & destination fields are being correctly written.
2921s are running IOS 151-4.M5
CUCM is 9.1.2.11900-12
Gateways are configured via MGCP.
Any ideas as to what's going on or how to fix it?
GTG
Please rate all helpful posts.
Can you attach a CDR example
Can you attach a CDR example as well as CallManager traces with the Enable CDR Trace flag set?
Have you tick the check box
Have you tick the check box thats says it should work cluster wide not only from the PUB or the SUB?
Voice CCIE #37771
33
