06-01-2014 12:09 AM - edited 03-16-2019 10:57 PM
Hi Experts,
when i tried to collect CDR file from CUCM GUI interface, i got the attached error. Moreover, when i do some investigations, i found " ERROR Failed to Flush writer, No space left on device"
In addition, when i tried to do manual puge, i found 10012 error. Also, i tried to find something on Real Time Monitoring Tool, i found " CDRAgentWriterFailed"
I noticed something from RTMT which is i am using 100% from common partition..
I attached some errors i faced..
Please advise
06-01-2014 02:23 AM
Based on "ERROR Failed to Flush writer, No space left on device", i would suggest the following:
1. Disable any detailed traces, set them to info or error level.
2. Delete traces through RTMT to free up some space
3. Restart the server after checking that all CDR related services are up an running
4. if the issue persists i would suggest an upgrade to at least 6.1.5 before getting into any traces, as 6.1.2 has numerous bugs for all kinds of issues.
Manish
06-01-2014 03:43 AM
06-01-2014 10:08 AM
Try restarting the server after deleting logs worth 30-40 days.
Manish
06-01-2014 03:34 AM
Hi Manish,
i went to RTMT ---system---tools---trace---Trace & log Central---double click on collect files---choose differnet logs & traces with delete files option. Then restart the server But with no result. common partition is still 100%
Do you have any ideas?
06-01-2014 10:37 AM
Hi Kamal,
Install "ciscocm.free_common_space_v1.0.cop.sgn" and check this should free up some space.
Mohammed Noorulla Khan
