05-11-2008 01:03 AM - edited 03-15-2019 10:35 AM
Hi Friends,
I am getting following CDR Error
destDeviceNamein a CDR record is null. 49.67
directoryNum in an Origination CMR record is negative. 0.20
dateTimeConnect in a CDR record is not a positive integer
Please help me out in resolving it.
Also I could find zero calls for any outgoing calls details . what could be the problem ?
Thanks and Regards
Rajesh
05-11-2008 09:10 AM
was this working before?
any changes?
is CDR configured correctly?
Data is Absent in Reports Created by the CAR Tool
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008056bd4e.shtml#cause2
javalenc
if this helps, please rate
05-12-2008 06:57 AM
Hi javalenc,
I couldnt find anything wrong on the configuration. Screenshot of configuration parameters are attached. I am finding one wrong thing. The output of top n calls is not giving a genuine report. It is not showing details on outgoing calls for majority of numbers (say for particular values of callerids).
It will be really gratefull if you could help me out on solving the issue
Thanks and regards
Rajesh
