Community Member
CDR Export on CUCM 6.0
I have found numerous posts on exporting CDR records directly from the SQL database on previous (Windows based) versions of CUCM. How does one do that on the Unix based 6.0?
1 ACCEPTED SOLUTION
Re: CDR Export on CUCM 6.0
under serviceability
tools -> CDR management
there is an option to configure a billing server to which you can push the info
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
javalenc
java
234
