CDR Fields
I would like to know is there any field named "Department"in CDR report.If no, then is there any unused editable field where i can put "Department" entry.
regards
Neo
1 REPLY
Re: CDR Fields
You configure it under end user
java
if this helps, please rate
java
www.cisco.com/go/pdi
189
