Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
CDR for incoming calls
We are running UCM 6.1. Recently I pulled a CDR report for a department. I only see outgoing calls on the report. Is there a way to configure CDR to generate reports for incoming calls too? Thanks,
Yiwen
Re: CDR for incoming calls
You can get it from here:
User Reports > Top N > By Charge or by duration
then it will be the " incoming " part of your report which represent Inbound calls that originate outside the Cisco Unified Communications Manager network and enter the Cisco Unified Communications Manager network through a gateway.
wish this be helpful
Best Regards
CDR logs all calls, you cannot configure it for only inbound or only outbound
java
if this helps, please rate
java
www.cisco.com/go/pdi
I tried it and got what I needed. Thanks!
Yiwen
303
