CDR for only specific Dialing
I am using CCM 4.2(3) and mgcp gateway in IPTelephony setup. I enabled CDR and now i can get report for All Calls based on CMC or other criteria. My question, is this possible i just enable CDR for specific calls like for specific Route Pattern. Actually i enabled CDR only for international calls so that i could bill based on CMC and want to get just international calls report.
Waiting for your positive response.
Best Regards
Re: CDR for only specific Dialing
Still waiting.........
Best Regards
no CDR, is for ALL calls and cannot be configured to log only certain information
java
if this helps, please rate
java
www.cisco.com/go/pdi
actually ramez , no you cant have CDR for only a specific route patterns , but if you really need this iguess you can configure the call manager to generate CAR reports for calls to a specific route pattern
Good Luck ;)
105
