CDR in CCM 5.x and CCM 6.x
Hi all,
I want to ask about CDR raw files comparison between CCM 5.x and CCM 6.x
Is there any difference between the CDR raw files of the two versions ? May be someone who has implemented both versions can show me what are the differences?
For third party billing system applications, they really need to know about this, because if it's different, it means they have to make new codes to support the raw files.
Any reply will be appreciated.
Thanks all.
Wiyandi
Super Bronze
Re: CDR in CCM 5.x and CCM 6.x
There are a number of changes between versions 4.x and 5/6.x.
The CDR format/definition will change with each version to accomodate new features, and the schema is published on cisco.com.
The way in which CDRs should be obtained has also changed in the Linux model.
In versions 4.x, CDR was in the SQL database and accessed via ODBC.
In 5.x upwards, the CM server outputs CDR to an FTP server, which must be provided by your CDR management application.
Hope this helps
Aaron
Please rate helpful posts....
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron,
Thanks a lot. Where can I find the CDR schema as you said before ?
Wiyandi
We are running UCM 6.1.2.
We are planning to deploy third party call billing software.
Can UCM 6.1.2 will support ODBC connectivity?
Programming Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
look for the data dictionary for the version on which you're interested
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
190
