01-22-2014 06:43 AM - edited 03-16-2019 09:22 PM
I am working on way to query the CDR on a CUCM publisher to display call detail information. I've noticed that the
CDR / CMR Files Preservation Duration (Days) field can not be increased over 30 days on the CDR Management page - which I take to mean that I can not bring up records older than 30 days. Is this a correct assumption? Isn't there a way to increase it to maybe a year?
Solved! Go to Solution.
01-22-2014 07:01 AM
Hi Shikamarunara,
Hope all is well my friend
One year is not possible, but you might be able to keep them
for 180 days before being purged depending on the amount of
records based on the High Water mark (not configurable).
This section describes how to schedule and disable automatic purging of the CAR database. By default, the system enables automatic database purge.
Procedure
Step 1 Choose System > Database > Configure Automatic Purge.
The Configure Automatic Database Purge window displays. At the top of the window, the percentage amount of the CAR database space that has been used gets displayed. The maximum CAR Database space that is available gets displayed in megabytes.
Step 2 From the Low Water Mark drop-down list box, choose the minimum percentage of the maximum CAR database size that you want the system to use for CAR data. The default value specifies 80 percent.
Tip The system notifies you when the CAR database size reaches the low or the high water mark; it also notifies you when the CAR database size exceeds the maximum number of records. For information on configuring an e-mail alert, see the "Enabling or Disabling Alerts by Mail" section on page 36-4, for instructions.
Step 3 From the High Water Mark drop-down list box, choose the maximum percentage of the maximum CAR database size that you want the system to use for CAR data. The default value specifies 90 percent.
Step 4 In the Max Age of Call Detail Records field, enter the maximum number of days that you want to keep the CDRs in the CAR database. Enter a number between 1 and 180. The default value specifies 60 days.
CAR deletes all CDRs that are older than the specified number of days.
Note To restore the default values for the fields in this window, click the Restore Defaults button.
Step 5 Click the Update button.
The changes take effect at midnight. To make changes take effect immediately, restart the Cisco CAR Scheduler service.
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/service/8_6_1/car/carsydb.html
Cheers!
Rob
"Seek it out and ye shall find "
- OneRepublic
01-22-2014 07:01 AM
Hi Shikamarunara,
Procedure
Cheers!
Rob
- OneRepublic
01-22-2014 07:07 AM
Hey Rob,
Thanks for responding (how's the weather up north?)
That's interesting, I guess third party solutions must be pulling the records and querying them locally because I'm pretty sure they can store the data for much longer. The earliest date I have information on is December 2nd.
01-22-2014 07:13 AM
You usually configure a billing server to which the CDR flat files are sent for further processing by the 3rd party app, then you can keep them for as long as you want, either in the CSV format, or by getting the data into a DB.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
