CDR more than 100 records CUCM 9.1
Is there any way to pull a report from CDR in CM 9.1 with more than 100 records? I am trying to get a total call count to our main number over a week.
Any ideas?
2 ACCEPTED SOLUTIONS
Hi William,
This is by design. Please check the Cisco Unified CDR Analysis and Reporting Administration Guide, Release 9.1(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/9_1_1/car/CUCM_BK_C28A807A_00_cdr-analysis-reporting-admin-guide91_chapter_011001.html
Manish
Re: CDR more than 100 records CUCM 9.1
As per the doc the CDR Search reports generate only in HTML format and are limited to 100 records per search. However, CSV and PDF options are available for User Reports, system Reports and Device Reports, and they will allow you to get more than 100 records.
Manish
Hi William,
Manish
So how do I get what the boss is asking for? I know the data is there....
Manish
A couple of workarounds are : You can use a sql query to generate a report on the CLI of the Publisher like the one below
run sql select * from car: tbl_billing_data where CallingPartyNumber ='XXXX'
But you will need to copy such reports and edit them to make them readable.
Alternatively, you can use third party billing servers ( there are quite a few available like Avotus and others ) and they should be able to provide the required reports.
Manish
Do you know of any free 3rd party CDR software?
Also thank you for pointing out CSV exports more than 100 rows!
Here is the link listing a few of them. Please discuss your specific requirements with them before going for any of them.
http://my.safaribooksonline.com/book/telephony/1587051397/administering-call-detail-records/ch11lev1sec13
Manish
Hey thank you for this!
I have a DBA, what is the connection string to connect to the CDR database? Do you know?
Not sure about that, let's see if someone else can respond. You can try seraching on google though for any hints.
Manish
VIP Purple
Hi William,
you can also visit the site http://www.variphy.com/products/free-trial  and get CDR reports.
regds,
aman
Hey William,
Unfortunately we don't allow direct ODBC, or driver connections to CUCM.
We support running SQL encoded in SOAP messages through what we call the AXL API. The API is freely available and documented, but requires a little coding. This is how UCCX and other products query the CUCM database.
The SQL API via command line was already pointed out by Manish.
There's quite a few 3rd party Billing software, but we try not to propaganda on the site. A Google search will give you good hits.
Hi William,
I can also recomend to take a look here: http://www.2ring.com/ca
2Ring's solution provides a really powerfull reporting.
Feel free to give me a feedback via this thread if you need any help.
Martin
Any idea of a approx price of 2Ring?
594
