Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CDR Multiple Sites
I have a Call Manager 7.1 that is soon to be running different sites. I need some type of report that is going to give me a breakdown of each site individually.  Will the CDR tool allow me to create multiple reports for each site.  When I look at it, for example Bills > Department, it makes me select users individually each time I want to run a report which is rather painstaking.  Is there any way to setup a "template" that will run a scheduled report for each site and all of the encompassing users?  The documentation is very unclear on creating templates or multiple site reports.  It seems you have to create reports every time.
1 REPLY
Re: CDR Multiple Sites
No, you cannot modify or create new reports in CAR.
If you need that, i'd suggest you to look into 3rd party solutions.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
162
