CDR no data on CUCM 7.x
Tommer Catlin
My services are running and has been since day one, but I can not get any data out of it.
Missing something?
chadlincoln
Level 3
Level 3
7 Replies 7
htluo
Level 9
Level 9
Be more specific? What does mean no data? From where you see no data?
Michael
I enter in an extension for running a report define a date and submit and comes back with 300100 no data
Sorry. not meant to be a pain, but the more information you gave, the more quickly we can locate the problem.
Did you mean you went to CUCM CAR web page > you logged in > you click 'CDR' > 'By User/Extension' > you enter 300100 and set the time range from 5/4/2009 12:00am to 5/5/2009 11:59pm > you click 'OK' and it returns nothing?
Michael
oh yeah, no worries. I entered in extension 1315. entered in a data, hit submit and I get back 10021 no matching records.
That means the data was not found in the database.
Please keep in mind that CDR/CAR is a two phase process - the flat files and the database.
If it's not in the database, it could be caused by one of the following:
1) The data was in the flat files, but not being loaded into database.
2) The data was not in the flat files at all.
You may go to CAR > System > Log Screen > Event Log > Move "CDR Load" from left to right. Then set the time range for the past couple days.
See if the CDR load was successful or not?
Michael
chadlincoln
Level 3
Level 3
Did you follow the guide to set it up?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_0_1/car/cmcarbk.html
Please rate if this helps.
Im an idiot. I did not enable the CDR flags on the service parameter for CUCM advance.
Thanks fellas
