ā04-26-2010 02:13 PM - edited ā03-15-2019 10:29 PM
I have a output CDR File, in this appear this field of Forced Autorization Code
authCodeDescription | authorizationLevel | clientMatterCode |
VARCHAR(50) | INTEGER | VARCHAR(32) |
Abigail Lozano | 20 | |
Agustin Lopez | 30 | |
Alfredo Sanchez R | 60 | |
Araceli Saules | 60 | |
Claudia Rosales | 20 | |
Hector Galindo | 30 |
Then in the third Field not appear the code number that the client dial to get access to PSTN.
Any Idea to show the value in this field.
Ivan Mendoza
ā04-26-2010 03:02 PM
Hello Ivan,
FAC and CMC are different concepts. CMC will just record a value for accounting purposes and let the call go through while FAC will check for the autorization level. If you are using FAC and would like to know the actual code they press you should be looking at field authorizationCodeValue.
ā04-26-2010 03:15 PM
I'm Look at field and this but also this is in blank
authorizationCodeValue |
VARCHAR(32) |
I must to configure something to do that this authorization Code Value appear.????
ā04-26-2010 06:12 PM
Ivan,
There's actually a service parameter in CallManager that determines if the value you input is recorded into the Flat file. It's called something like Display FAC in CDR. Make sure it's enabled in every CUCM server.
Cheers,
