Community Member
CDR Question
Does CDR capture Forced Authorization Code (FAC) when used by a user?
Does it mark it with the PIN code or description.
1 REPLY
Re: CDR Question
Yes, CDR has the info.
CAR already has CMC/FAC reports built into it.
java
if this helps, please rate
java
www.cisco.com/go/pdi
131
