CDR Records Problem
Dears,
Please be informed that i am facing a problem with CDR records. when i try to retireve them i am not able to get the records for the last 10 days.
Suppose that i retrieved them today(28 June) i will be able to view until 18 June only .
Kindly advice what could be the cause of the problem and how can we solve it.
Thank you for your help,
Mirna Khadra
Everyone's tags (3)
1 ACCEPTED SOLUTION
CDR Records Problem
Check in Serviceability -> Tools -> CDR Management what your settings are under "General Parameters". CUCM is purging the records out of it's database based on parameters set there.
GTG
Please rate all helpful posts.
CDR Records Problem
GTG
CDR Records Problem
Dear Gordon,
You can find in the attached image the settings under "General parameters".
Do we have to change any of the parameters?
Awaiting your feedback,
Thank you your reply
CDR Records Problem
There's nothing obviously wrong there. (The settings are the same as on my system, and my data goes back to end of May)
Is your system very busy ?
GTG
CDR Records Problem
Yes our system is very busy.
CDR Records Problem
In which case there's just not enough room in the DB to hold all the calls, so they're getting purged out.
At the end of the day, the CUCM CDR/CMR DB is just a buffer for external data sinks. External 3rd party tools are much better at handling large amounts of data and running all sorts of reports on them.
GTG
CDR Records Problem
Hi Gordon,
Do you thing this issue could be related to a bug ?
Note that the version of our CUCM is 7.1.3
CDR Records Problem
Massive appologies. I've just realised that I've mis-read your question . Time for a slice of humble pie.
Check that CDRs haven't become disabled. System -> Service Parameters -> (Server) -> CallManager -> CDR Enabled Flag. (It's near the top of the list)
GTG
CDR Records Problem
the CDR enable flag is set
Note that we are able to collect the CDR records but the last 10 days no :
Records from 31/5/2012 to 20/6/2012 are available today
Records from 31/5/2012 to 19/6/2012 were available yesterday
Mirna
421
