CDR Records Purging by CCM 4.1
In my CCM 4.1 the MAX CDR Records is set as 1500000. I want to know how CCM purges the record when the count reaches 1500000. Does it deletes all of them at once(or it deletes them based on some condition?) and the records again start increasing from 0 to 1500000.
Rajesh
Re: CDR Records Purging by CCM 4.1
it simply starts deleting oldest records, think of this as a circle, once you complete a whole turn you start writing were you started
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks.
But does it keep on deleting from the oldest till the count becomes zero?
and then waits for the record count to become 1.5million before it starts to purge again?
thanks
I thought the circle example would be enough, apparently not
If you have 10 slots and imagine them in a circle, the next element to 9 would be the 0
0123456789
When you reach data 11 you replace 0, 12 replaces 1, 13 replaces 2, etc and so on til the end of times. You never really delete, but rather replace data.
It's a circle, you replace the elements.
When you write data 1,500,001 you delete the 1st entry you have in DB, which is the oldest and so on
Is it clear now?
java
java
119
