CDR report for CIPC
Bhavani Sankar
Hi All,
Good evening. I have a query. Can we pull CDR report for a persons IP communicator separately and the desk phone separately from call manager?
Sankar.
yahsiel2004
Level 7
Level 7
You can export all CDRs and organize the results in Excel. But without a third party tool, I don't think you can extract that information from a CUCM "CAR" drop down.
Yosh
HTH Regards, Yosh
Jaime Valencia
No, assuming they're a shared line, you'll get all calls from that line in the report.
If they're separate lines, just run a report on each DN.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
