CDR report for SIP trunks in CUCM 6.1.2
Is there a way in CDR reports to get a report of incoming calls on SIP trunks?
I was trying to do a gateway detail report which lists the calls on
selected gateways, and has the number called, the calling number, etc
but under gateway types there is not an option for a SIP trunk or any
kind of trunk anywhere. The gateway summary report only shows calls
for a remote H323 gateway, but we're looking for inbound calls on the
clients main telephone company trunks which are all SIP.
This is on a Call Manager version 6.1.2-1000.
Re: CDR report for SIP trunks in CUCM 6.1.2
Hi!
You can check this bug:
CSCsk87140
Symptom:
Calls through an H.323 or SIP Trunk do not show up in the gateway utilization
reports in the CDR Analysis and Reporting Tool on Cisco Unified Communications
Manager.
Conditions:
Using the Gateway Utilization report to monitor trunk utilization.
Workaround:
None
The bug is New and I believe there's no fix yet.
Regards, Tere. If you find this post helpful, please rate! :)
Thanks.
So, there is no option in CDR to get call reports on these calls without using a third party tool now?
I was working with a customer
I was working with a customer with the same issue/question, I found this support forums while researching the issue, but there wasn't enough info. I'd like to share the Steps Done/ Resolution of that case:
Problem Description:
Customer wants to get CDR reports for their SIP trunks specifically.
CUCM 10.5.1.10000-7
Actions Taken:
-From the CDR tool if we filter by "Gateways" we only see H323 and MGCP gateways, SIP trunks don't come up.
-If we try to filter by “Trunks” specifically, we only have the option to extract "Utilization" information, which only displays bandwidth usage info, not calls info.
-After further investigation, it looks like the only way to export SIP trunk calls information on CDR is to do a full export:
I provided these steps:
1-Go to CDR Analysis and Reporting> Export CDR/CMR> Enable CDR records only> Click on "Export file".
2-Go to Excel> Open > Look for that file. On the import wizard select "Delimited" instad of "Fixed width"> Next>  Check "Comma" as the Delimiter> Finish
3-You can use Control+F and navigate on the file, some filters that can be used are:
"callingPartyNumber"
"originalCalledPartyNumber"
910
