Community Member
CDR report shows internal calls
hI
When i runn the CDR reports it show internal ip phone to ip phone calls also.
how i can stop this that in my CDR report i dont want to see internal calls
1 REPLY
You can't CDR logs ALL calls, there's no way to just have it log internal or external
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
169
