Community Member
CDR Report
Hii all,
In CCM 5.1, can I generate the Destination and Origin Name name in CDR Call Report?
Thanks & Regards
Madhab
Re: CDR Report
these are the options that currently are available:
CDR Search Configuration
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/5_1_3/car/carsrch.html
Configuring CDR Search by User Extension
Configuring CDR Search by Gateway
Configuring CDR Search by Cause for Call Termination
Viewing Call Termination Details
Configuring CDR Search By Call Precedence Levels
Configuring CDR Search for Malicious Calls
You can go thru the document or just try CAR reports to find all the possible options.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Re: CDR Report
Hiii,
thanks for useful help. I think there are no option for generate the Destination name in CDR Report page.
Thanks & Regards
Madhab
Re: CDR Report
yes, unfortunately there is no such option with the provided CAR tool
javalenc
java
151
