09-04-2007 06:24 AM - edited 03-14-2019 11:22 PM
I can see an entry for Woking subscriber from the Publisher, but it would appear that the subscriber isn?t writing anything to CDR database on the Publisher.
What can I do?
Solved! Go to Solution.
09-04-2007 09:14 AM
CDR Enable flag in CCM Service Parameters should be set to TRUE in all the servers in the cluster that have IP Phones|GWs registered to them.
Make sure that DBL is up and running and there are no flat files in CDR folder and subfolders.
09-04-2007 09:14 AM
09-05-2007 04:37 AM
Thanks. But what do you mean by flat files in CDR folder and sub folder?
09-07-2007 01:59 AM
Thank you. Problem resolved.
05-13-2013 03:10 AM
Hi, facing the same issue, CDR on subscriber dont work anymore after cluster rebuild. in service parameters everything seems ok.
How did you solve it?
Br,
Goran
