Community Member
CDR reports on total calls in
Hi. I'm running CCM 5.1.2 with CAR enabled. I am trying to get a fairly simple report but am new to this and having trouble getting to the right place.
Basically I need to know the number of external calls are coming into all extensions. Only external calls, not internal-to-internal.
Then I need to know, of those calls, how many are getting forwarded to our voicemail extension (3216)?
I'm figuring I'll need to run two reports: one with all extensions(minus 3216), and another with only 3216.
Is this do-able?
Tim
Re: CDR reports on total calls in
CAR does not provide means to choose only external or only internal calls, you get ALL calls when running reports.
You can refer to the docs to understand CAR capabilities
Cisco Unified CallManager CDR Analysis and Reporting Administration Guide, Release 5.1(3)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/5_1_3/car/car.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
The only thing you can do here is to create your own reporting tool that gets the data from the SQL table of the CM publisher server like we did. we created an excel (microsoft visual basic) program to pull what we needed or just a simple sql query would do.
hth
Community Member
Okay, if I export the CDR data to Excel it gives me calling #, called #, and destination #. After that it's just sorting it out with a script or something. Thanks for the help.
138
