CDR Service Activation
Hi!
In the ?Service Activation? window the service ?Cisco CDR Insert? is active. When I enter the ?Server Parameters Configuration? window it does not appear.
I would like to configure the CDR Service parameters but this way it is impossible!
1 REPLY
Hall of Fame Super Silver
Re: CDR Service Activation
The CDR service parameters are found under CallManager Service, you need to enable the following service paramters:
CDREnabled
CallDiagnosticsEnabled
HTH,
Chris
136
