CDR size? what's the normal size?
I have problems that depends of CDR file size. CDR ldf is about 7 Gb size. Where can I read about requirements about size of CDR database and how can I resolve this problem?
Silver
Re: CDR size? what's the normal size?
Attached is a document about shrinking the database which I think will help you...
Please rate if useful.....
CDR data should have a fixed size of 5GB and should not grow any larger than that, you can try deleting some records thru CAR
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
And how I should save the capacity of CDR database about 5 Gb?
458
