CDR Subscriber
Hi.
I have a cluster CCM 5.x (1 publisher and 1 subscriber)
CDR is run in both servers.
I think that just the publisher write the bills. But if the publisher's down. The subscriber have a capability of write de bills?
Re: CDR Subscriber
CAR DB is only on the PUB as in all versions
so if you want to use CAR you need connectivity to the PUB
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Re: CDR Subscriber
So, If PUB down. I don't have bills. Correct?
VIP Super Bronze
Re: CDR Subscriber
Yes,
Beacuse when your publsiher is down, you cannot read into the data ase to pull out the CDR
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: CDR Subscriber
200
